  1. I have some animations made with Flash MX and I wnat to burn them on DVD so I can watch them on DVD player? Make it simple as it could be! Please!
    I have Pioneer 104 DVD/RW on my PC and my player is Pioneer 355!
    london uk
    ive allways wondered this aswell i think you can export you flash animation to an a mpeg file from flash mx then you can use TMPGEnc to convert it to an dvd mpeg file then burn it that might work but i havent tried it
    Staind // 14 Shades Of Grey // Buy It
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it's been a while since I used Flash, and I haven't used MX, but is there an option to export to an AVI, and select compression?
    if so, export to AVI with a low-compression codec like Huffyuv or PicVideo MJPEG, and use a MPEG encoder like TMPGenc or MainConcept to convert it to dvd-mpeg.
    this should give you better results than exporting as an mpeg-1 and converting to mpg-2, as the previous poster seems to suggest.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
